alexandre3253
Jan 12, 2023Tutor
R8500 + EAX80
Hello, I have a R8500 purchased in US. I am traveling to Europe and want to buy the EAX80 extender. If I buy it in Europe, will it work with my R8500 purchased in US? Will they work or is there any ...
Jan 12, 2023Guru - Experienced User
EU has different broadcast restrictions.
And the north america versions are locked to north america.
Are you staying in EU long? If its permanent, buy the EAX in europe.
If its a brief stay, buy it in the US. You might have some broadcast issues but basically set your channels to avoid the EU restricted ones.
michaelkenward
Long or short, buying in Europe might be best.
They don't lock the region here, going by all the things I have used. So you should be able to buy in Europe and than
switch to the US when you return home.
- alexandre3253Jan 13, 2023Tutor
Thank you all. I will let you know.
