Netputter
Jul 14, 2016Aspirant
R8500 1.0.2.64 Firmware killed WiFi printing on Canon MF5950dw, No resume from sleep with WiFi on
I upgraded R8500 firmware from 1.0.2.54-1.0.56 to 1.0.2.64-1.0.62 last night, I can no longer print wirlessly from Windows10 to Canon Imageclass MF5950dw or MF8380cdw. I now have to restart printer ...
- Jul 24, 2016
I found the solutuion my self....
Fix wireless printing to Canon Imageclass printers after firmware 1.0.2.64 upgrade kills it.
Login to your router, "http://routerlogin.net"
Click "Advance" Tab,found on top of display
Click "Advance Setup" in left column
Click "Wireless Settings" and look for section labelled "Wireless Advanced Settings (2.4Ghz b/g/n)"
Remove check mark, from box infront of "Enable 20/40 MHz Coexistence"
Apply Settings and log off.
Enjoy Reliable Wireless Printing after your firmware upgrade.
VE6CGX
Jul 14, 2016Master
Was there particular reason you updated firmware? Logic tells me, you better go back to the previous f/w. I always wait to make sure new firmware works B4 I move to update new firmware. Often firmware breaks something else while trying to something. Firmware update is serious matter.
- aalexandrebetaJul 15, 2016Master
Wifi stuff should be banned while we are sleeping! On my R8500 only the 2.4Ghz remain open!
