FECJR
Aug 06, 2018Tutor
R8500 and iRacing
I have searched the community forums extensively for a solution to the dreaded "Receiving throughput dropped below acceptible rate" message. I've seen several good posts on setting QOS on other Netg...
- Aug 10, 2018Asus RT-AC5300. Flawless operation. Simple setup.
DarrenM
Aug 10, 2018Sr. NETGEAR Moderator
You may want to take a look at this KB
https://kb.netgear.com/24266/How-to-enable-Quality-of-Service-QoS-on-routers-with-NETGEAR-genie
DarrenM
- FECJRAug 10, 2018TutorYou're kidding, right? The issue is with a R8500, which has Dynamic QoS, at mentioned in the original post. As a moderator, I'd think you knew that or at least researched it a bit.
After four hours on the phone with tech support, it was determined that the R8500 will ONLY work with iRacing when DMZ is set up. Too risky for my network. Router has been discarded. Competitor's comparable router installed and working.
