peter11742
Dec 07, 2016Luminary
R8500 bricked
Hi All. This is my first report. I purchased on purpose the above router on Ebay. I can not register it Serial 4DG65B7G019C5 it is used like mint. The reason i found it is the best range router an...
- Dec 16, 2016
This is my final procedure after I fixed the second router r8500.
1) J4 connector pins : 1 2 3 4 pins are visable by looking the motherboard and they are located in the front view.
and j4 mark is located next to #1 pin. 1 gets green color, 2 gets white color, 3 gets green color, 4 is not connected.
2) open the bottom cover by removing the 6 tork screws.
Take the cover half way out so you can see the j4 plug and plug the serial cable.Turn on the router.
3) Start Putty let it run for a minite or so and start sending control c commands until you will see CFE.
4) on CFE type nvram erase you will see a 0 as an answer.
5) On CFE type tftpd you will get tftpd server ready ::
6) go on comand mode dos cmd>tfttp -i 192.168.1.1 put C:\r85.chk
r85.chk will be your old firmware located on the c:\ main directory
7) Now you will see a blue led on the #1 port flickering comminicating.
8) if what you did is correct then you will get from dos and putty file tranfered successful.
9) Now hold the reset button with a pin and turn the power off.
10) with the pin on reset turn power on and waight for 3 reboots let the pin go.
11) waight for 2 minutes you will see many led's comunicating and final the main led will be normal.
12) The router is now ready to be configuerd.
13) The network name and password is located on the white paper top right or at the bottom of the router.
I did 2 units the first one it took 1 week the second one it .5 hour.
Good luck.
peter11742
TheEther
Dec 07, 2016Guru
I believe the serial port is the 4-pin header at the bottom of this picture halfway between the middle and left hole. Image credit: smallnetbuilder.com.
peter11742
Thanks.
I knew the CPU chassy I love it.
I f you read my report I need to control the software that is corrupted.
I have all the required adaptors and software.
Your help will be appreciated.
peter11742
- peter11742Dec 07, 2016Luminary
Many thanks for this reply.
This is the page I started original to fix the router.
This is where I have a problem.
He is mentioning in the beginning ( Verify that the serial client has proper parameters to the connection.)
I use PUTTY but I have a difficulty to make it to find the router it always fails.
Is any special settings that I have to make let me know.
I can ping IP:54.218.118.186 and IP: 54.200.99.0 that GENIE found for me.
When I set this ip's with GENIE or PUTTY the connection fails. I use cat5 connection and ttl-usb on the motherboard.
I still can not make any good steps.
Best regards.
Peter11742
- TheEtherDec 07, 2016Guru
Make sure you have the drivers for the PL2303 installed. I use the drivers from Prolific. It has a program to check that it can reach the PL2303. This will help you identify the correct COM port. Interestingly, on my laptop, only one of the USB ports works with my cable.
Try these serial port settings:
115200 baud, but you can go lower
8 bits
No parity
1 stop bit
On the router, you only need to connect the Tx, Rx and GND pins to the cable. You can leave the VCC pin unconnected.
Good luck.
