peter11742
Dec 07, 2016Luminary
R8500 bricked
Hi All. This is my first report. I purchased on purpose the above router on Ebay. I can not register it Serial 4DG65B7G019C5 it is used like mint. The reason i found it is the best range router an...
- Dec 16, 2016
This is my final procedure after I fixed the second router r8500.
1) J4 connector pins : 1 2 3 4 pins are visable by looking the motherboard and they are located in the front view.
and j4 mark is located next to #1 pin. 1 gets green color, 2 gets white color, 3 gets green color, 4 is not connected.
2) open the bottom cover by removing the 6 tork screws.
Take the cover half way out so you can see the j4 plug and plug the serial cable.Turn on the router.
3) Start Putty let it run for a minite or so and start sending control c commands until you will see CFE.
4) on CFE type nvram erase you will see a 0 as an answer.
5) On CFE type tftpd you will get tftpd server ready ::
6) go on comand mode dos cmd>tfttp -i 192.168.1.1 put C:\r85.chk
r85.chk will be your old firmware located on the c:\ main directory
7) Now you will see a blue led on the #1 port flickering comminicating.
8) if what you did is correct then you will get from dos and putty file tranfered successful.
9) Now hold the reset button with a pin and turn the power off.
10) with the pin on reset turn power on and waight for 3 reboots let the pin go.
11) waight for 2 minutes you will see many led's comunicating and final the main led will be normal.
12) The router is now ready to be configuerd.
13) The network name and password is located on the white paper top right or at the bottom of the router.
I did 2 units the first one it took 1 week the second one it .5 hour.
Good luck.
peter11742
peter11742
Dec 12, 2016Luminary
Updates.
The red light is only for rebooting the green comes later.
I had the router for hours and it works good.
Now I said is time to update it, netgear dowloaded the updates and they installed them.
Now I got the problem back is rebootnig.
NEVER ASK FOR UPDATES they do not work.
peter11742
peter11742
To all.
This is my last report we are done.
The people that they do not like the R8500 router are wrong.
This router is confiquered and it covers all my house it beats my new Linksys by a mile.
When i read the specifications I new this router is champ it has the best lenth coverage from all of them.
Good luck to all and happy holidays.
I will still answer all my emails I will help any one that has problems with this good router.
The next project will be the x10 that will bricked let us get ready.
The router is not getting hot just worm.
Best regards.
peter11742
- raven_auDec 12, 2016Virtuoso
Glad to hear you finally got there.
I agree, my R8500 is unusually stable compared to quite a few other high end routers I have.
- peter11742Dec 13, 2016Luminary
Thank you.
We are in agrrement.
With the old software the router boots in 2 minutes but it boots and is good.
Happy holydays.
peter11742
- peter11742Dec 16, 2016Luminary
Good luck.
peter11742
- peter11742Dec 20, 2016Luminary
Hi.
A small correction.
Pin #1 green Pin #2 white pin #3 blk which is the gound Pin #4 is not connected red.
peter11742
- Alabama62Dec 30, 2016Guide
I have established a PuTTY connection but only get garbage. I have verified my serial connection to be appropriate, i.e. transmit and receive and ground. CTRL C does not work for me. I have tried numerous times. restarting the router and trying etc. Any suggestions?
- peter11742Jan 02, 2017Luminary
Hi.
It is your computer causing this issue. Check your serial settings and much them with our explained settings.
Read all my my problems and you will see I had to get a good laptop with a good win 10 and it worked.
If your establist comunication is good then you will see good text.
All my settings are explained and all my issues are answered.
Good luck.
Peter11742
- raven_auJan 04, 2017Virtuoso
Alabama62 wrote:I have established a PuTTY connection but only get garbage. I have verified my serial connection to be appropriate, i.e. transmit and receive and ground. CTRL C does not work for me. I have tried numerous times. restarting the router and trying etc. Any suggestions?
What does "I have verified my serial connection to be appropriate, i.e. transmit and receive and ground." mean?
How do you know it is correct since you clearly have a problem that usually indicates it isn't?
Have you tried switching transmit and receive around?
- peter11742Jan 04, 2017Luminary
Hi.
Please verify that the red cable is not connected.
Verify that the name of the plug is locating your #1 pin green.
Verify that your blk cable will be the third pin and the fourth pin is not connected.
Now you have to hit control c at the beginning of the reset of the router when you will see a lot of numbers.
Your serial port baut rate has to changed until you see real characters.
Good luck.
peter11742
- Alabama62Jan 04, 2017Guide
It was the baud rate. 115200 worked. Loaded firmware, router working like new. Thanks for all the help.
Hi.
I am very happy to hear this.
Now do not make the mistake and update the router, if you do you have to start all over again.
peter11742
- raven_auJan 06, 2017Virtuoso
peter11742 wrote:Hi.
peter11742
Not being able to update the router firmware is not really acceptable.
I expect that no-one on this thread will be willing to subject themselves to Netgear support particularly to discuss an issue like this, they'll probably play the "not supported" card anyway and not even bother to collect any information to pass on to engineering.
But it would be good to get this infomation to Netgear engineering and even better to get some feedback as to what might be happening.
AFAICS this, or a very similar problem, is causing considerable cost to Netgear in terms of replacing faulty units so it should be something we can get their attention for.
So, to the Netgear folks watching the forum, how about opening a dialogue with engineering?
- ElaineMJan 09, 2017NETGEAR Employee Retired
I apologize but our scope of support is limited especially when the hardware has been opened.
- raven_auJan 11, 2017Virtuoso
ElaineM wrote:I apologize but our scope of support is limited especially when the hardware has been opened.
The fact that the only way to fix the NVRAM corruption caused by the router firmware is to open the router should be something engineering want to fix.
If they are happy to just replace routers when this happens then so be it but it is happening far too often!
Perhaps it is a hardware fault with some devices and there is no choice but to replace the devices, but the people on this topic need to know that too.
And, if it is a harware fault, what about those people that have devices that are not long out of warrantee?
Given the price of this device the problem isn't being handled well at all!
Ian
- peter11742Jan 16, 2017Luminary
Hi All.
I have no issues with any warranty.
I bought a product that it is still in warranty but the serial number was entered by the previous owner and of course Netgear rejected.
I do not ask for favors, I ask for my legal rights that the software is corrupted but it can not be restored.
I learn that the header in the nvram is corrupted. The new version of the nvram is looking for this header it does not find it and corrupts bricks the router.
As an engineer I never created software that will change my original selection.
So far I lost my faith for a good software update.
I use the router with it's original software and of cource I have only 2x 5 mhz channels and none 1x 2 mhz channel.
I will have more information soon.
I will find how to create a new header on the nvram eprom.
Peter 11742.
- peter11742Feb 06, 2017Luminary
Hi all.
After all this past time I found still we can not update the new software version.
Let me know if any one has any better news.
Peter11742
- demonstrativeJul 11, 2017Aspirant
Hi Peter11742
I was going through this thread "R8500 bricked" earlier because i am encountering a similar situation R8000. I followed your steps but encountered some differences. I was wondering if you could lend me some advice.
Just some background, i bought a bricked router R8000 from someone who claimed it is fully working. After i realised it was bricked, i decided to get serial cable, disassembled the chassis to fix it. Please bear with me as this is the first time i am doing this to a router, i usually use routers off the shelf.
Back to the steps you have listed. using it as a checklist so you can see the steps i completed.
and j4 mark is located next to #1 pin. 1 gets green color, 2 gets white color, 3 gets green color, 4 is not connected. Done
Take the cover half way out so you can see the j4 plug and plug the serial cable.Turn on the router. Different router, i remove everything until i get the pcb board, plugged in my USB-TTL cable (similar to serial cable) Done.
3) Start Putty let it run for a minite or so and start sending control c commands until you will see CFE. If i wait for a minute to start sending control C command, I cannoit get into CFE. so i started once putty starts. I got into CFE.
4) on CFE type nvram erase you will see a 0 as an answer. Done
5) On CFE type tftpd you will get tftpd server ready ::Done
At any time now press control c untill you see CFE run nvram erase get a 0. Done
On CFE enter tftpd and waight there. Done, but see screenshot below. PuTTy just stops there, router lights also stops blinking. believe it is turned off. Is it supposed to be like this? Do i continue with the next step of going to doc cmd?
Any help will be appreciated. Thank you in advance!
Demonstrative
- TheEtherJul 11, 2017Guru
The tftpd command tells the router to wait for a TFTP transfer. You need to initiate the transfer from an Ethernet connected PC or Mac.
- peter11742Jul 12, 2017Luminary
Hi.
You forgot to connect your PC with the dos command and the specific instructions see my procedure.
Follow my instructions and repeat the procedure it works.
Best regards.
Peter11742
- demonstrativeJul 12, 2017Aspirant
Sorry my bad. i forgot to mention that the Ethernet cable has been connected from the beginning.
After starting TFTP , I typed in cmd>tftp -i192.168.1.1. put C:\R8000-V1.0.44_1.0.96.chk firmware
I waited for the pop up you mentioned, but there was just nothing happening.
Can i check if the line i type is correct?
my R8000....chk file is placed in C:
- peter11742Jul 25, 2017Luminary
You forgot to have a space ON -i 192.168.1.1. -i192.168.1.1. put C:\R8000-V1.0.44_1.0.96.chk firmware
Be sure that the firmware is the first version firmware from Netgear.
If you did all the procedure correctly you should observe the data led that is flsfhing with the data.
Re do the procedure and let us know.
peter11742
- demonstrativeJul 27, 2017Aspirant
Hi peter11742
please see screenshot. Connect request failed.
any idea why this happens? am i misssing any steps? - TonyGeJul 29, 2017Aspirant
Hi All.
I am stuck on CFE after following all the steps in this thread, I have Putty connected, but getting the following error:
data cheksum validation failed. Any idea if possible to get CFE prompt?
- peter11742Jul 29, 2017Luminary
The only solution that I can tell you is the following.
Take the power from all you devises off that means the router and your computer.
Now work on your router alone Make a procedure that resets the router by pressing the reset button and waiting 30 seconds.
Now you can start again with the putty and dos procedure. It should work because I had this problem and now the router works with the first firmware from NetGear. Good luck.
Peter11742
Thank you, Peter.
I have already tried that before. Reset is totally dead and not doing anything. I did power off/on, 30/30/30 reset, nothing seems to work on this router. Putty always brings same message when checking EEPROM.
