peter11742
Dec 07, 2016Luminary
R8500 bricked
Hi All. This is my first report. I purchased on purpose the above router on Ebay. I can not register it Serial 4DG65B7G019C5 it is used like mint. The reason i found it is the best range router an...
- Dec 16, 2016
This is my final procedure after I fixed the second router r8500.
1) J4 connector pins : 1 2 3 4 pins are visable by looking the motherboard and they are located in the front view.
and j4 mark is located next to #1 pin. 1 gets green color, 2 gets white color, 3 gets green color, 4 is not connected.
2) open the bottom cover by removing the 6 tork screws.
Take the cover half way out so you can see the j4 plug and plug the serial cable.Turn on the router.
3) Start Putty let it run for a minite or so and start sending control c commands until you will see CFE.
4) on CFE type nvram erase you will see a 0 as an answer.
5) On CFE type tftpd you will get tftpd server ready ::
6) go on comand mode dos cmd>tfttp -i 192.168.1.1 put C:\r85.chk
r85.chk will be your old firmware located on the c:\ main directory
7) Now you will see a blue led on the #1 port flickering comminicating.
8) if what you did is correct then you will get from dos and putty file tranfered successful.
9) Now hold the reset button with a pin and turn the power off.
10) with the pin on reset turn power on and waight for 3 reboots let the pin go.
11) waight for 2 minutes you will see many led's comunicating and final the main led will be normal.
12) The router is now ready to be configuerd.
13) The network name and password is located on the white paper top right or at the bottom of the router.
I did 2 units the first one it took 1 week the second one it .5 hour.
Good luck.
peter11742
Alabama62
Dec 30, 2016Guide
I have established a PuTTY connection but only get garbage. I have verified my serial connection to be appropriate, i.e. transmit and receive and ground. CTRL C does not work for me. I have tried numerous times. restarting the router and trying etc. Any suggestions?
raven_au
Jan 04, 2017Virtuoso
Alabama62 wrote:I have established a PuTTY connection but only get garbage. I have verified my serial connection to be appropriate, i.e. transmit and receive and ground. CTRL C does not work for me. I have tried numerous times. restarting the router and trying etc. Any suggestions?
What does "I have verified my serial connection to be appropriate, i.e. transmit and receive and ground." mean?
How do you know it is correct since you clearly have a problem that usually indicates it isn't?
Have you tried switching transmit and receive around?
- peter11742Jan 04, 2017Luminary
Hi.
Please verify that the red cable is not connected.
Verify that the name of the plug is locating your #1 pin green.
Verify that your blk cable will be the third pin and the fourth pin is not connected.
Now you have to hit control c at the beginning of the reset of the router when you will see a lot of numbers.
Your serial port baut rate has to changed until you see real characters.
Good luck.
peter11742
- Alabama62Jan 04, 2017Guide
It was the baud rate. 115200 worked. Loaded firmware, router working like new. Thanks for all the help.
Hi.
I am very happy to hear this.
Now do not make the mistake and update the router, if you do you have to start all over again.
peter11742
- raven_auJan 06, 2017Virtuoso
peter11742 wrote:Hi.
peter11742
Not being able to update the router firmware is not really acceptable.
I expect that no-one on this thread will be willing to subject themselves to Netgear support particularly to discuss an issue like this, they'll probably play the "not supported" card anyway and not even bother to collect any information to pass on to engineering.
But it would be good to get this infomation to Netgear engineering and even better to get some feedback as to what might be happening.
AFAICS this, or a very similar problem, is causing considerable cost to Netgear in terms of replacing faulty units so it should be something we can get their attention for.
So, to the Netgear folks watching the forum, how about opening a dialogue with engineering?
- ElaineMJan 09, 2017NETGEAR Employee Retired
I apologize but our scope of support is limited especially when the hardware has been opened.
- raven_auJan 11, 2017Virtuoso
ElaineM wrote:I apologize but our scope of support is limited especially when the hardware has been opened.
The fact that the only way to fix the NVRAM corruption caused by the router firmware is to open the router should be something engineering want to fix.
If they are happy to just replace routers when this happens then so be it but it is happening far too often!
Perhaps it is a hardware fault with some devices and there is no choice but to replace the devices, but the people on this topic need to know that too.
And, if it is a harware fault, what about those people that have devices that are not long out of warrantee?
Given the price of this device the problem isn't being handled well at all!
Ian
- peter11742Jan 16, 2017Luminary
Hi All.
I have no issues with any warranty.
I bought a product that it is still in warranty but the serial number was entered by the previous owner and of course Netgear rejected.
I do not ask for favors, I ask for my legal rights that the software is corrupted but it can not be restored.
I learn that the header in the nvram is corrupted. The new version of the nvram is looking for this header it does not find it and corrupts bricks the router.
As an engineer I never created software that will change my original selection.
So far I lost my faith for a good software update.
I use the router with it's original software and of cource I have only 2x 5 mhz channels and none 1x 2 mhz channel.
I will have more information soon.
I will find how to create a new header on the nvram eprom.
Peter 11742.
- peter11742Feb 06, 2017Luminary
Hi all.
After all this past time I found still we can not update the new software version.
Let me know if any one has any better news.
Peter11742
