aalexandrebeta
Feb 26, 2017Master
R8500 console access procedure
How to acces the router remotly?
- Feb 26, 2017
You can telnet into router. You can use a telnetenable executable that's freely available on the Internet (use the correct one for your model). Alternatively, it may be possible to enable telnet access through a debug menu (e.g. http://routerlogin.com/debug.htm). I saw a post recently about that.
Once you are in, it's pretty much a BusyBox console.
TheEther
Feb 26, 2017Guru
Console access usually refers to access via serial port. This is different from remote access. Which one are you asking about?
- aalexandrebetaFeb 26, 2017Master
Let me clarify the question, Is there a way to access the raw datas on the router, such as the way the router sees the USB drives or printer or temperature.
- TheEtherFeb 26, 2017Guru
- aalexandrebetaFeb 28, 2017Master
TheEtherI know 3 stuff to access thru telnet but as you are a wiseman I need to be lectured a bit and to feel less stupid! So do you have some docs or procedure or stuff like this to enlight me a bit!!
Thanks!
