aalexandrebeta
Feb 26, 2017Master
R8500 console access procedure
How to acces the router remotly?
- Feb 26, 2017
You can telnet into router. You can use a telnetenable executable that's freely available on the Internet (use the correct one for your model). Alternatively, it may be possible to enable telnet access through a debug menu (e.g. http://routerlogin.com/debug.htm). I saw a post recently about that.
Once you are in, it's pretty much a BusyBox console.
TheEther
Feb 26, 2017Guru
Console access usually refers to access via serial port. This is different from remote access. Which one are you asking about?
aalexandrebeta
Feb 26, 2017Master
Let me clarify the question, Is there a way to access the raw datas on the router, such as the way the router sees the USB drives or printer or temperature.
- TheEtherFeb 26, 2017Guru
- aalexandrebetaFeb 28, 2017Master
TheEtherI know 3 stuff to access thru telnet but as you are a wiseman I need to be lectured a bit and to feel less stupid! So do you have some docs or procedure or stuff like this to enlight me a bit!!
Thanks!
