aalexandrebeta
Feb 26, 2017Master
R8500 console access procedure
How to acces the router remotly?
- Feb 26, 2017
You can telnet into router. You can use a telnetenable executable that's freely available on the Internet (use the correct one for your model). Alternatively, it may be possible to enable telnet access through a debug menu (e.g. http://routerlogin.com/debug.htm). I saw a post recently about that.
Once you are in, it's pretty much a BusyBox console.
aalexandrebeta
Feb 26, 2017Master
Let me clarify the question, Is there a way to access the raw datas on the router, such as the way the router sees the USB drives or printer or temperature.
TheEther
Feb 26, 2017Guru
