roger567
Dec 21, 2020Tutor
R8500 fails to connect
For some months now, the router fails to connect to websites and displays messages like "Hmmm… can't reach this page www.website.com took too long to respond". Usually if I click refresh the websit...
roger567
Dec 21, 2020Tutor
The R8500 connects via ethernet to the ISP's router (called a Centro Business 2), which is in PPPoE passthrough mode.
The ISP's router connects directly to the fibre optic cable that goes to the outside world.
The R8500 handles the internet connection (user ID, password etc.).
Dec 21, 2020Guru - Experienced User
the centro might be in passthrough mode but I've seen that mode not function properly before.
have you tried running it in router mode and putting the R8500 in access point mode?
- roger567Dec 21, 2020Tutor
Thanks, I will switch it over and try it for a few hours to see if it is different.
It has been in PPPoE mode for some years without problems and the problem started some months ago.
Presumably I can keep the R8500 as DHCP server and have the Centro doing as little as possible.
- plemansDec 21, 2020Guru - Experienced User
If you have the centra in router mode and the R8500 with dhcp, you're still in a double nat.
- roger567Dec 22, 2020Tutor
Switching the Centro to router mode gave very similar results.
Replacing the R8500 with an R7500 and putting the Centro back to PPPoE seems to work well.
Still it is early days, I will try running the R7500 for as long as they let me keep it to see if it just got lucky, or whether it really is different.
