xphogt00
Jan 11, 2022Aspirant
R8500 Firmware V1.0.2.156 broke MMO
Hello, After deploying the latest firmware update (V1.0.2.156), I am seeing a pause to load several websites and one of my MMOs (Secret World Legends) is no longer able to connect. That is the o...
Jan 11, 2022Guru - Experienced User
First try enabling ipv6 if its not.
If that doesn't help, you might need to downgrade the firmware a version.
Yours isn't the first R8500 that I've seen with issues on the latest
- xphogt00Jan 11, 2022Aspirant
Thank you for the suggestion. It was disabled. Which of the many ipv6 modes would you suggest I try?
