xphogt00
Jan 12, 2022Aspirant
R8500 Firmware V1.0.2.156 broke MMO
Hello, After deploying the latest firmware update (V1.0.2.156), I am seeing a pause to load several websites and one of my MMOs (Secret World Legends) is no longer able to connect. That is the o...
xphogt00
Thank you for the suggestion. It was disabled. Which of the many ipv6 modes would you suggest I try?
DexterJB
Jan 30, 2022NETGEAR Moderator
Hi xphogt00, are you still experiencing the issue? If yes, have you tried the suggested step (Auto Detect should be just fine)?
Dexter
- xphogt00Jan 31, 2022Aspirant
Thank you checking up! Auto Config seemed to work best. It did solve the issue.
- FURRYe38Jan 31, 2022Guru - Experienced User
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-routerPlease mark your thread as solved so others will know.
Enjoy. 📡
