Martycp
Feb 17, 2018Follower
R8500 Firmware Version 1.0.2.116
Don't upgrade to the latest firmware version 1.0.2.116 for R8500. I have 2 external HDD connected for network storage and when i upgraded to 1.0.2.116, the router didn't recognise i had anything plug...
- Feb 22, 2018
Hi Martycp,
Upgrade the firmware and then reset the router. Configure it manually after the reset.
BORIS48
Mar 15, 2018Aspirant
I have bought new R8500 and at once was updated to this FW.
I have a problem with USB 3.0. If not to take out USB 3.0 from USB 3 port that after reset a router doesn't see USB 3.0. I solve a problem so: before reset of a router I take out USB 3.0 from USB 3 port and after hard reset of a router I insert and only then the router sees the USB stick again. Why NETGEAR won't solve this problem in any way?
