Old__Goat's avatar
Feb 21, 2019
R8500 Firmware Version 1.0.2.130 Performance Drop
Yesterday, I upgraded my R8500 fireware to 1.0.2.130.  All functionality seems to be working the same. However, SpeedTest shows my download performance dropped from months of data points in the 170-1...
  • Old__Goat's avatar
    Old__Goat
    Feb 21, 2019
    Answers to your questions:
    1) I started in the advanced menu and went page by page turning off most features to see if any fixed the performance.
    2) I looked for the past firmware versions in two places. There was no link on the current 1.0.2.130 download page, and none listed next to it in the previous page.
    What I learned after that:
    1) The missing link to previous versions was actually on the "Downloads" page but not listed with the current version. It was seperate in a different font at the bottom of the list. It was easy to overlook it there after all the other links that were clearly not what I was looking for.
    2) Once I downloaded an older version and reset to factory defaults the performance was restored. I then tried upgrading again to the current version and performace was still good. I  then reload the saved configuration since it had large tables of access list and other setting likely to take several hours to reenter manually. The problem came back.
    3) Another pass at the settings by hand looking for the problem and I found it. Dynamic QoS seems to have been locked down to a low number in the update install, without a way to restore the performance. Turning off Dynamic QoS restores performance. SpeedTest seems to be limited by its own previous low value. Manually setting reasonable values for the expected performance restores good results to SpeedTest runs. I manual set it as 190Mbps and now measure it with Speedtest at 178 Mbps.
