DirtyWilly
Aug 20, 2021Star
R8500 Latest Firmware Version V1.0.2.154 Broke DNS!
Hello, the latest firmware version V1.0.2.154 for the R8500 router appears to have broken DNS! I have to refresh pages multiple times to get them to load. Attached is the most common error. DNS_PR...
stealth18
Sep 18, 2021Tutor
1.0.2.154 has been working great for the past 2 weeks now on both my Macbooks. Noticed less lags/lower latentcies even when it's busy. .144 firmware has been crashing occasionally - 5Ghz signals would disappear from time to time until it gets rebooted.
Unit is on Access Point mode - and DHCP is running on a separate router/fw.
.144 was really dissapointing. I was going to ditch Netgear for good and go with other brand name. But .154 seems to be running great so far.
DirtyWilly
Oct 13, 2021Star
This is the same behavior I've seen. 144 faster than 154 (though 144 is not as fast as previous firmwares so clearly something was done to DNS) And on occasion 144 crashes router.
- webleeOct 13, 2021Guide
the same results I had ..
...we are behind 2 firmware revisions...I work from home and cant play around.
- plemansOct 13, 2021Guru - Experienced User
weblee do you have IPv6 enabled? try enabling it if not and doing a reboot.
- webleeOct 16, 2021Guide
I have not but I will give that a shot when I have time available to work on the router.
My latest "UhOH" event - 2 hours with nothing in the log!!! NOTHING! On a business day!
Something is seriously wrong.
