DirtyWilly
Aug 20, 2021Star
R8500 Latest Firmware Version V1.0.2.154 Broke DNS!
Hello, the latest firmware version V1.0.2.154 for the R8500 router appears to have broken DNS! I have to refresh pages multiple times to get them to load. Attached is the most common error. DNS_PR...
DirtyWilly
Jan 06, 2022Star
I WFH as well so a stable home connection is important. However, I do enjoy gaming and it tends to dictate my hardware choices. The Asus has a dedicated LAN port just for gaming, takes priority over all network traffic among other updated packed-features.
CaledonKen
Mar 15, 2022Star
Any posters on this thread that were having DNS issues with the previous firmware releases, have you tried version 158? Do the issues still persist?
- SSP2020Mar 15, 2022Guide
I'm still using V1.0.2.144 and not upgraded to V1.0.2.158 as I don't want to Screw my work from Home.
if anyone upgraded please share the Experience.- FURRYe38Mar 15, 2022Guru - Experienced User
"If it works, don't fix it."
- webleeMar 15, 2022Guide
I did…not as consistent a problem but the same issues. The problem is I have not been able to erase and down rev to eliminate these issue!
- FURRYe38Mar 16, 2022Guru - Experienced User
Should be able to factory reset and download older FW:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
I recommend using the ERASE button under Advanced tab/Admin/Backup
