ericgarvin
Aug 24, 2018Aspirant
R8500 Nighthawk router not working
Having problems with network going down. Current components are a cm600 modem, a 8500 router and a gs116 switch. All netgear products. I was watching hulu on an Apple Tv last night and the boys we...
- Sep 05, 2018Yup I am back up. I just disconnected the whole lot and reset my network. I also realized that I had one cable creating a loop on the switch. I am confident that was really the problem. I must have done this after the original reset.
DarrenM
Aug 28, 2018Sr. NETGEAR Moderator
Any updates on your network is it back up?
DarrenM
- ericgarvinSep 05, 2018AspirantYup I am back up. I just disconnected the whole lot and reset my network. I also realized that I had one cable creating a loop on the switch. I am confident that was really the problem. I must have done this after the original reset.
- myerswSep 07, 2018Master
ericgarvin wrote:
Yup I am back up. I just disconnected the whole lot and reset my network. I also realized that I had one cable creating a loop on the switch. I am confident that was really the problem. I must have done this after the original reset.Don't you hate it when you create your own problems? ;)
Yes I suspect the loop you created was your network issue.
