ericgarvin
Aug 24, 2018Aspirant
R8500 Nighthawk router not working
Having problems with network going down. Current components are a cm600 modem, a 8500 router and a gs116 switch. All netgear products. I was watching hulu on an Apple Tv last night and the boys we...
- Sep 05, 2018Yup I am back up. I just disconnected the whole lot and reset my network. I also realized that I had one cable creating a loop on the switch. I am confident that was really the problem. I must have done this after the original reset.
myersw
Aug 29, 2018Master
Normal first step would be to Ethernet attach PC in place of router and see if things worked then. If so then it has to do with the router, If not then you get to fight with the ISP.
