Dootchie
Apr 01, 2016Guide
R8500 not registering ReadyCLOUD
Hi I bought the R8500 Nighthawk Router and I connected my WD My Book Essential 2Tb (model WDBACW0020H8K-01) and I change the share name to "MyDrive" and I'm able to get to my drive by doing \\mydrive...
- Apr 04, 2016
Kindly verify if removing any special character in your password will work.
afgeekfamily
May 04, 2016Tutor
I have tried all the suggested fix actions to get my router and my usb device to register with ReadyCloud. I have created a password that is really basic with no special characters, still no joy!! I am able to connect to my ReadyShare through smb and have even successfully downloaded, installed and signed in to the ReadyCloud app for Mac. Any suggestions would be welcomed. I just want to use my data anywhere I am and not be tethered to my local Wifi network. I am using firmware version is V1.0.2.54_1.0.56.
Dootchie
May 04, 2016Guide
Hi, what worked for me was I had to change my Cloud password to NOT have special Characters (remove $,#,@,!, etc). After I did that I was able to log into the admin screen (http://routerlogin.net/) and Register my Cloud device
- afgeekfamilyMay 05, 2016Tutor
So the password has to be even more basic than the one I originally put in. I can't believe how stupid of a password I put in for this to work, but it is working. Thank you.
