baforer1954
Oct 28, 2023Guide
R8500 OpenVPN 3.4.0 not working
I updated the OpenVPN app on my iPhone to 3.4.0 and now I get an unsupported option error when I try to connect. It says something about a server only option. I looked at the configuration files but d...
- Nov 08, 2023I received a DM from a NETGEAR representative and was told that the RAXE300 currently does not support OpenVPN 3.4.0. An update will be coming but there currently is no timetable for it. I was told that the RAXE500 and RS700 currently do work with OpenVPN 3.4.0
baforer1954
Oct 29, 2023Guide
The unsupported option is push.
In the ovpn file is the following
sndbuf 393216
rcvbuf 393216
push “sndbuf 393216”
push “rcvbuf 393216”
sndbuf 393216
rcvbuf 393216
schumaku
Oct 30, 2023Guru - Experienced User
Comment the push lines in the config file for the moment.
OpenVPN does as a quick fix the availability of older versions to install.
OpenVPN Connect app: "Connection Failed. Unknown/unsupported options present in configuration."
Either way, Netgear seems to have has some massive backlog updating the OpenVPN implementation on virtually all routers supporting OpenVPN, including the generated (suggested) config blocks on all devices following the OVPN 3.4 ff. requirements. DarrenM (all Nighthawk), DavidGo (all Orbi), and probably even BH_C ref. the new RS700 ...
