baforer1954
Oct 28, 2023Guide
R8500 OpenVPN 3.4.0 not working
I updated the OpenVPN app on my iPhone to 3.4.0 and now I get an unsupported option error when I try to connect. It says something about a server only option. I looked at the configuration files but d...
- Nov 08, 2023I received a DM from a NETGEAR representative and was told that the RAXE300 currently does not support OpenVPN 3.4.0. An update will be coming but there currently is no timetable for it. I was told that the RAXE500 and RS700 currently do work with OpenVPN 3.4.0
Oct 31, 2023Guru - Experienced User
Might post about that here in this forum:
Check here as well:
baforer1954
Nov 08, 2023Guide
- baforer1954Nov 12, 2023Guide
OpenVPN 3.4.1 addresses the unsupported option issue.
