Alex_CCIM's avatar
Alex_CCIM
Apprentice
Mar 24, 2017
R8500 OpenVPN isn't connecting via iPhone
Hello All,
My R8500 doesnt connect via OpenVPN on my iPhone 7+.
I have tried the following:
  • Factory Reset & restored settings
  • Re-downloading the VPN scripts.
  • Upgraded to latest Firmware: V1.0.2.94_1.0.79
Here are the relevant Router Log entries:
[OpenVPN, connection fail]IP address:XXX.XXX.XX.XX Wednesday, Jan 01,2003 00:03:31
[OpenVPN, connection fail]IP address:XXX.XXX.XX.XX Wednesday, Jan 01,2003 00:02:48
Here are the iPhone OpenVPN log entries:
2017-03-24 09:02:59 ----- OpenVPN Start ----- OpenVPN core 3.1.2 ios arm64 64-bit built on Dec  5 2016 12:50:25
2017-03-24 09:02:59 Frame=512/2048/512 mssfix-ctrl=1250
2017-03-24 09:02:59 UNUSED OPTIONS
3 [sndbuf] [393216]
4 [rcvbuf] [393216]
5 [push] [sndbuf 393216]
6 [push] [rcvbuf 393216]
8 [resolv-retry] [infinite]
9 [nobind]
10 [persist-key]
11 [persist-tun]
17 [verb] [0]
2017-03-24 09:02:59 EVENT: RESOLVE
2017-03-24 09:03:00 Contacting YY.YYY.YYY.YY:12973 via UDP
2017-03-24 09:03:00 EVENT: WAIT
2017-03-24 09:03:00 SetTunnelSocket returned 1
2017-03-24 09:03:00 Connecting to [NOIP.dynns.com]:12973 (YY.YYY.YYY.YY) via UDPv4
2017-03-24 09:03:00 EVENT: CONNECTING
2017-03-24 09:03:00 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client
2017-03-24 09:03:00 Creds: UsernameEmpty/PasswordEmpty
2017-03-24 09:03:00 Peer Info:
IV_GUI_VER=net.openvpn.connect.ios 1.1.1-212
IV_VER=3.1.2
IV_PLAT=ios
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO=1
IV_AUTO_SESS=1
2017-03-24 09:03:00 VERIFY OK: depth=1
cert. version    : 3
serial number    : AD:F8:8A:46:C7:E3:72:03
issuer name      : C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, [email protected]
subject name      : C=TW, ST=TW, L=Taipei, O=netgear, OU=netgear, CN=netgear, [email protected]
issued  on        : 2015-11-08 04:51:35
expires on        : 2025-11-05 04:51:35
signed using      : RSA with MD5
RSA key size      : 1024 bits
basic constraints : CA=true
2017-03-24 09:03:00 VERIFY OK: depth=0
cert. version    : 3
serial number    : 01
subject name      : C=TW, ST=TW, O=netgear, OU=netgear, CN=netgear, [email protected]
issued  on        : 2015-11-08 04:51:38
expires on        : 2025-11-05 04:51:38
basic constraints : CA=false
cert. type        : SSL Server
2017-03-24 09:03:00 NET Internet:ReachableViaWWAN/WR t------
2017-03-24 09:03:40 Session invalidated: KEEPALIVE_TIMEOUT
2017-03-24 09:03:40 Client terminated, restarting in 2000 ms...
2017-03-24 09:03:42 EVENT: RECONNECTING
2017-03-24 09:03:42 EVENT: RESOLVE
2017-03-24 09:03:42 Contacting YY.YYY.YYY.YY:12973 via UDP
2017-03-24 09:03:42 EVENT: WAIT
2017-03-24 09:03:42 SetTunnelSocket returned 1
2017-03-24 09:03:42 Connecting to [NOIP.dynns.com]:12973 (YY.YYY.YYY.YY) via UDPv4
2017-03-24 09:03:42 EVENT: CONNECTING
2017-03-24 09:03:42 Tunnel Options:V4,dev-type tun,link-mtu 1558,tun-mtu 1500,proto UDPv4,comp-lzo,cipher AES-128-CBC,auth SHA1,keysize 128,key-method 2,tls-client
2017-03-24 09:03:42 Creds: UsernameEmpty/PasswordEmpty
2017-03-24 09:03:42 Peer Info:
IV_VER=3.1.2
IV_PLAT=ios
IV_NCP=2
IV_TCPNL=1
IV_PROTO=2
IV_LZO=1
IV_AUTO_SESS=1
2017-03-24 09:03:42 VERIFY OK: depth=1
cert. version    : 3
2017-03-24 09:03:42 VERIFY OK: depth=0
cert. version    : 3
serial number    : 01
2017-03-24 09:03:59 EVENT: CONNECTION_TIMEOUT [ERR]
2017-03-24 09:03:59 EVENT: DISCONNECTED
2017-03-24 09:03:59 Raw stats on disconnect:
  BYTES_IN : 5702
  BYTES_OUT : 75071
  PACKETS_IN : 54
  PACKETS_OUT : 168
  KEEPALIVE_TIMEOUT : 1
  CONNECTION_TIMEOUT : 1
  N_RECONNECT : 1
2017-03-24 09:03:59 Performance stats on disconnect:
  CPU usage (microseconds): 146787
  Network bytes per CPU second: 550273
  Tunnel bytes per CPU second: 0
2017-03-24 09:03:59 EVENT: DISCONNECT_PENDING
2017-03-24 09:03:59 ----- OpenVPN Stop -----
I appreciate any help that I can get.
Thank you,
-Alex
  • Hello All,
    I fixed my own problem.  It had nothing to do with my router.  It had to do with my AT&T Uverse router.  I had some additional settings to tweak in order to open up additional ports and firewall settings so that my R8500 would be wide open on the internet.  Long story short: My VPN is working again.
    -Alex
1 Reply
  • Hello All,
    -Alex
