Darksangle
Apr 30, 2018Follower
r8500 random disconnect while downloading
my router keeps disconnecting from the internet but only while downloading somtimes it even says internet status good but doesnt connect to the inernet i have to re apply the settings or reboot the d...
- May 27, 2018
Hi microchip8,
Can you check this firmware.
https://kb.netgear.com/000058809/R7800-Firmware-Version-1-0-2-52
Hi Darksangle,
Try this.
https://kb.netgear.com/000058826/R8500-Firmware-Version-1-0-2-122
JamesGL
May 03, 2018NETGEAR Employee Retired
Hi Darksangle,
Have you tried to reset the router to factory default?
microchip8
May 04, 2018Master
When you say "while downloading" do you mean maxing out the router's bandwidth or your ISPs line bandwidth?
I had a similar occurance on my R7800 yesterday when downloading at ~480 Mbps. It suddenly stopped and I had no internet connection while the router's GUI says all is fine. After a minute or so, it fixed itself magically. I was too slow to login with telnet and see dmesg output and logs so I don't know what exactly happened. I've downloaded in the past with same speeds mentioned for up to half an hour with not a single interruption
- microchip8May 04, 2018Master
OK, I did some further testing on latest V1.0.2.46 firmware for the R7800. I also get consistant same behavior as to what the OP describes
Downloading here at ~480 Mbps cuts off internet after 5-10 minutes and the GUI says it has no WAN connection. I will do some testing on an older firmware and see how it goes
Confirmed that on version 1.0.2.40 and below for the R7800 it does not happen - however download speed fluctuates much more than on higher versions but at least it does not cut you off from Internet and GUI does not report as WAN being down after ~10-15 minutes of continous high-speed (480 Mbps and up) downloading. Can you escalate it with engineering ?
