Tommyboy_308-88
Feb 15, 2021Follower
R8500 reboot loop
I am having some issues with my R8500 Router/Wifi, after doing an firmware update my power light been flashing for about 5 hrs so i looked online and did this step thinking would work. After doin...
Feb 15, 2021Guru - Experienced User
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
