mikegoldnj's avatar
mikegoldnj
R8500 slow download speeds
I currently have 200 Mbps speed with my cable provider.   If i connect from modem, directly to my laptop via gigabit ethernet, I get speedtest results above the 200 Mbps speed.   I understand tha...
  • ElaineM's avatar
    Nov 28, 2016
    Welcome to the community, mikegoldnj
    Do you have the latest firmware installed on the router?
    What is your connection type? IPv4 or IPv6?
    If you do not have the latest firmware yet, kindly install it and then do a factory reset on the router.
