AudiTuner
Oct 12, 2015Star
R8500 slow upload speeds (v1.0.0.50_1.0.25)
Have tried the R8500 v1.0.0.50_1.0.25 firmware multiple times but end up downgrading back to v1.0.0.42_1.0.23 each time since uploads are incredibly slow on v1.0.0.50_1.0.25 (~.2mbps instead of ~12mb...
NightOwl326
Nov 13, 2015Luminary
Still no resolution with upload speeds on .56 firmware as they are still 1/3 of what they have been with every other router for years.
ElaineM
Nov 13, 2015NETGEAR Employee Retired
NightOwl326 Did you reset after the firmware upgrade?
Kindly PM me the following info:
- Number of computers (wired and wireless)
- Operating systems of each computer
- ISP
- Brand of the modem
- Do you have a USB drive connected to the router? If you do, remove it then check.
- How do you test the speed? On a wired or wireless pc? What software (i.e speedtest.net)?
- If you're using wireless, which signal you're connecting to (2.4Ghz, 5Ghz, 5Ghz-2)?
- Will experience low upload speeds on wired connection?
- How often do you experience the problem?
PM me as well a copy of your configuration file. The configuration file is the same as backup config of your router.
You will need to use a dropbox or any file sharing site in order for me to download the config file.
By the way, make sure to use the default login for the admin page ("admin" & "password") of the router.
