AudiTuner
Oct 12, 2015Star
R8500 slow upload speeds (v1.0.0.50_1.0.25)
Have tried the R8500 v1.0.0.50_1.0.25 firmware multiple times but end up downgrading back to v1.0.0.42_1.0.23 each time since uploads are incredibly slow on v1.0.0.50_1.0.25 (~.2mbps instead of ~12mb...
snagalin
Oct 19, 2015Aspirant
Hi CraigAJohnson,
Please check the Qos setup under Advanced tab on Router configuration page. Please change it to "Manually type the download / upload speed" and type the download / upload speed for your internal plan.
CraigAJohnson
Oct 19, 2015Guide
Selva,
I enabled QoS and manually modified the download and upload speeds. No change.
I reverted to v1.0.0.42 of the BIOS. No change.
Occasionally, after rebooting the router, an internet upstream test is successful and I may be able to run it a couple more times before the upstream test fails.
Swapped out network cables. No change.
Something seems very wrong with this router.
