AudiTuner
Oct 12, 2015Star
R8500 slow upload speeds (v1.0.0.50_1.0.25)
Have tried the R8500 v1.0.0.50_1.0.25 firmware multiple times but end up downgrading back to v1.0.0.42_1.0.23 each time since uploads are incredibly slow on v1.0.0.50_1.0.25 (~.2mbps instead of ~12mb...
CraigAJohnson
Oct 19, 2015Guide
Glad the previous firmware (v1.0.0.42?) is working for you. I will also await the next firmware update. If something this basic isn't fixed by then, I will have no choice but to return the router (which I don't want to do).
AudiTuner
Oct 21, 2015Star
Just an update - I reverted back to v1.0.0.42_1.0.23 as it seems more stable. Hopefully this will be resolved soon.
- Lexist2112Oct 21, 2015Luminary
AudiTuner,
So you have QoS and Traffic meter enabled and no degradation of broadband speed on either wired or wireless???
Also, can you check to see if your able to do a speedtest on a wired desktop, using Firefox browser???
TIA
Lex
