zack466
Mar 29, 2020Aspirant
r8500 throttling connection?
I recently upgraded to a 400 mbps spectrum wireless internet plan. However, my R8500 router is giving me problems. It seems that the router is throttling the connection to my PC down to around 100 mb...
- Mar 30, 2020
zack466 wrote:
Modem: Netgear CM700. There is one ethernet port on the back, and it's connected straight into my router with a Cat6 cable.
Simple modem. No router bit to get in the way.
I have seen reports that even if you disable QoS the dratted thing does not pay attention. Try a reset after disabling QoS.
michaelkenward
Mar 30, 2020Guru - Experienced User
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router.
zack466
Mar 30, 2020Aspirant
Firmware version: V1.0.2.106
- michaelkenwardMar 30, 2020Guru - Experienced User
- zack466Mar 31, 2020Aspirant
I enabled and disabled QoS and restarted the router.
So far, the speeds have not dropped or been throttled by the router, so I'll assume the problem is fixed for now.
Thanks!
