zack466
Mar 29, 2020Aspirant
r8500 throttling connection?
I recently upgraded to a 400 mbps spectrum wireless internet plan. However, my R8500 router is giving me problems. It seems that the router is throttling the connection to my PC down to around 100 mb...
- Mar 30, 2020
zack466 wrote:
Modem: Netgear CM700. There is one ethernet port on the back, and it's connected straight into my router with a Cat6 cable.
Simple modem. No router bit to get in the way.
I have seen reports that even if you disable QoS the dratted thing does not pay attention. Try a reset after disabling QoS.
zack466
Mar 30, 2020Aspirant
Firmware version: V1.0.2.106
michaelkenward
Mar 30, 2020Guru - Experienced User
- zack466Mar 31, 2020Aspirant
I enabled and disabled QoS and restarted the router.
So far, the speeds have not dropped or been throttled by the router, so I'll assume the problem is fixed for now.
Thanks!
