chascent's avatar
chascent
Luminary
Nov 12, 2016
R8500-V1.0.2.80_1.0.71 - Port 68 shows closed NOT Stealth
Here we go again. I just got around to checking this and sure enough the Port 68 closed problem is back! I will not use a firmware that does not stealth ALL my ports.   Went back to DDWRT and ALL ...
  • chascent's avatar
    chascent
    Nov 18, 2016
    I reset modem, reflashed firmware, reset again then manually put in my settings.
    No ALL Stealth.
    CC
