chascent
Nov 12, 2016Luminary
R8500-V1.0.2.80_1.0.71 - Port 68 shows closed NOT Stealth
Here we go again. I just got around to checking this and sure enough the Port 68 closed problem is back! I will not use a firmware that does not stealth ALL my ports. Went back to DDWRT and ALL ...
- Nov 18, 2016
I reset modem, reflashed firmware, reset again then manually put in my settings.
No ALL Stealth.
CC
Retired_Member
Nov 15, 2016
What are you using to scan the ports. My port 68 is stealth as are the rest.
chascent
Nov 15, 2016Luminary
Shields up. Port 68 is Blue all others are green.
I install DDWRT and everything is stealth. Why is this? Its not my ISP for sure.
CC
- Retired_MemberNov 15, 2016
Can you test with a different PC
- chascentNov 15, 2016Luminary
I did that with 2 different Pc's same result. Thats the first thing I did.
I then thought it may be my ISP but that was proved wrong when I installed DDWRT.
Everything went Stealth on ALL pc's.
My seup had 15 static ip's, QOS on. UPNP disabled. Nothing fancy but that port not showing stealth
really bothers me.
CC
