chascent
Nov 12, 2016Luminary
R8500-V1.0.2.80_1.0.71 - Port 68 shows closed NOT Stealth
Here we go again. I just got around to checking this and sure enough the Port 68 closed problem is back! I will not use a firmware that does not stealth ALL my ports. Went back to DDWRT and ALL ...
- Nov 18, 2016
I reset modem, reflashed firmware, reset again then manually put in my settings.
No ALL Stealth.
CC
Retired_Member
Nov 16, 2016When using DDWRT did you notice if your Public IP was the same as when using stock FW.
I ask because it's possible your ISP has blocked port 68 based on IP address.
chascent
Nov 16, 2016Luminary
Same exact ip, I checked when I was running the tests.
Please let me know what you see with QOS on.
PS with QOS off the bufferbloat is terrible.
CC
- Retired_MemberNov 16, 2016
I tried every combo of settings and ALL were stealth. Last I checked BB was C with qos off. I don't use QOS since NG decided to use the preset settings.
- chascentNov 18, 2016Luminary
No ALL Stealth.
CC
- Retired_MemberNov 18, 2016
NOW OR NO?
- chascentNov 19, 2016Luminary
NOW ALL STEALTH..... All good!
CC
