JJW76
Jul 01, 2021Aspirant
R8500 Vs R6700v2
I'm trying to evaluate which model is best as I use the R6700 and recently acquired the R8500. Appreciate your thoughs or direction to resources to compare. Thanks.
- Jul 02, 2021
The R8500 is also a triband device. You could try reading a few reviews on them to see how they perform.
NETGEAR R8500 Nighthawk X8 Smart WiFi Router Reviewed - SmallNetBuilder
microchip8
Jul 02, 2021Master
The R8500 has a stronger/faster CPU from Broadcom and has more RAM. The R6700v2 uses a weaker MediaTek one with lesser RAM
R8500: http://en.techinfodepot.shoutwiki.com/wiki/Netgear_R8500
R6700v2: http://en.techinfodepot.shoutwiki.com/wiki/Netgear_R6700_v2
JJW76
Jul 02, 2021Aspirant
Thanks for your reply. How about signal strength and security?
Would you recomend the R8500?
- plemansJul 02, 2021Guru - Experienced User
