meldgr8t
May 22, 2016Aspirant
R8500 wireless bridge setup
Which of the two 5ghz band is the best or recommended one to use when setting up a wireless bridge on another R8500 router? Is it the first 5GHZ or the second 5GHZ SSID and PASSWORD?
- May 26, 2016
...finally got it working, can now log on to the wireless bridge router with static address, after having done multiple time of 'factory reseting' the router. Just for curiosity, factory resetting a router a few or multiple times, will it cause damage to the router?
Anonymous
May 22, 2016It shouldn't matter BUT, the 3 digit channels in the US have a higher output level if your link is weak use them.
