meldgr8t's avatar
meldgr8t
R8500 wireless bridge setup
Which of the two 5ghz band is the best or recommended one to use when setting up a wireless bridge on another R8500 router? Is it the first 5GHZ or the second 5GHZ SSID and PASSWORD?
  • meldgr8t's avatar
    meldgr8t
    May 26, 2016
    ...finally got it working, can now log on to the wireless bridge router with static address, after having done multiple time of 'factory reseting' the router.  Just for curiosity, factory resetting a router a few or multiple times, will it cause damage to the router?
