Mikey94025
Jun 02, 2016Hero
R8500 with latest V1.0.2.54_1.0.56 intermittently loses DNS
I replaced my R7000 very recently with a R8500 and am very pleased with the faster 5G speeds. I'm running the latest R8500 firmware, V1.0.2.54_1.0.56, but notice that my DNS disappears intermittentl...
- Jun 09, 2016
Mikey94025 How's the connection after reset? I'm unable to replicate the problem you're having. The router is working perfectly with the connection.
Perhaps, it's a faulty unit.
Mikey94025
Jun 03, 2016Hero
Thank you for that very detailed reply! I will do some careful inspection of my R8500 status if the problem happens again (so far not seen today). I only checked the internet status on the Advanced tab but will also check the Basic tab the next time.
drummin1
Jun 04, 2016Guide
Just FYI, but I had installed the Netgear Genie app on my work laptop which is wired direct to the Netgear. Sort of a minute by minute monitor of the path to internet. That was more depressing than the DNS errors themselves. Connectivity issues were popping up in my taskbar from the Genie more often than we were aware of. There may be smaller hiccups that occur more regularly than the ones you and I get frustrated by. They may go unoticed as we arent accessing the web 100% of the time to 100% of the throughput even if we sit at the computer all day. We stream Netflix, etc. and the buffer is large enough to maybe smooth out smaller burps but when we get the 25% loaded screen that hangs, we know the big belch has occured. I got so distracted by the steady taskbar popups from Genie that I just uninstalled it. TMI and right in my face while I'm supposed to be working.
I have an older work laptop. Perhaps I shall run the ping /t www.google.com from evening til morning. That'll give a second by second picture of it's performance. Pretty sad when I gotta have my router fill out a timecard, no?
Frontier has tested both phone lines and they perform nearly identically.
Glad your gonna eyeball the web interface when you can. It seems odd that one tile on the "basic" panel identifies a problem but the tiles on the "advanced" tab all have the green checkmarks and even show the OpenDNS server addresses, etc.
Good luck,
-Mike
- Mikey94025Jun 06, 2016Hero
Unfortunately my DNS outage happened twice again tonight (it was ~7pm, +/- 15 min). I was able to spend some time diagnosing and narrowed it to only DNS functionality through the R8500 itself:
- I can ssh to external hosts if I use an IP address. I can also make web requests via IP address.
- If I change my Windows adapter DNS from the router IP (192.168.1.1) to Google DNS (8.8.8.8) then the DNS and web browsing works again on my laptop.
- The R8500 Basic and Advanced tabs both reported that the Internet status was GOOD.
- The first time it failed I changing the R8500 DNS from "Get Automatically from ISP" to a static IP (8.8.8.8 and 75.75.75.75 - The Comcast DNS) but it did not restore the DNS. I changed it again to (8.8.8.8 and 8.8.4.4) and DNS came back. I've seen the issue with static DNS before so I don't think it matters and restarting the router just often restores the DNS.
- I was turning off random functions and DNS went away after I turned off UPNP (and so the router had to restart).
This doesn't seem like a hardware issue since it's so specific to DNS. I can always return the router if I have to, but I'd first want to try hard reset or downgrade the firmware.
- ElaineMJun 09, 2016NETGEAR Employee Retired
- Mikey94025Jun 09, 2016Hero
I did a reset of my router and then restored from a backup (I previously unboxed my new router with v1.0.0.something firmware, entered my settings, then did the firmware upgrade to V1.0.2.54 using the web tool and without a reset). I have not seen the DNS loss in the past few days, but it's not been that long yet and it would only be caught if I happen to notice it during my evening web use.
I tried installing the Netgear Genie on my Windows desktop PC (that I keep on all the time) to try and report if any DNS errors occur, but it doesn't seem to log if it happens and only shows a temporary taskbar error popup when it occurs. So I can't use it to tell me if DNS goes away intermittently. But I setup a script to ping a DNS name every 5 sec and log the results. I should now be able to see if DNS ever goes away during the next few days. If DNS stays working for 72 hours then we can assume that the reset cleared the issue.
