Omerta51
Oct 31, 2021Follower
R8500
The Nighthawk ax8 8500 power up lights Flash bottom front blue Wi-Fi light goes on but no Wi-fi lights on it in the front and no network shows on any of my devices for it I had it on for 2 days one ti...
Oct 31, 2021Guru - Experienced User
Does pressing the reset button for 10 seconds then release then wire connect a PC to the router and setup the router using a web browser have any effect?
Might try a different power adapter with same volt and amps...
