Chas2
Jul 13, 2023Aspirant
R8500
Hi, Good old spectrum just "updated" their system....oh, joy. Their tech who came out said that calls went from 250 a day to 1500 starting 2 months ago with the upgrades, which is when i noticed th...
Jul 13, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended
Chas2
Hi,
thanks for response, however i did hard power downs, reset button on router but the one thing their tech and i didn't do was bypass the router, duh.... and guess what....worked great...hard wired lap and got 371Mbps, 100 desk top old dell...can not log into router with ip and not seeing internet although led says it does so can't use web site.
is this what happens when bricked? anything i can do or use it as a doorstop?
using an old linksys for now.
- FURRYe38Jul 13, 2023Guru - Experienced User
Did you factory reset the R8500 with it not connected the ISP modem and see if you can complete the setup wizard. You can manually set it up with a PC and web browser.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. - michaelkenwardJul 13, 2023Guru - Experienced User
No.
"Bricked", a meaningless term that get thrown around willy nilly, usually means corrupt firmware. This shows up in the state of the power LED. If it is solid white, then it is not bricked.
To check this for yourself, read the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Troubleshoot With the LEDs.
.can not log into router with ip and not seeing internet although led says it does so can't use web site.It isn't easy to understand that string of "sound bites".
What is this router IP? (There are various options.)
What LED " says it does"? What colour? Blinking?
- Chas2Jul 13, 2023Aspirant
all the leds are white with wifi blinking....the ip i used to get in is the default gateway 192.168.1.1, this got me in but when i went to advanced it went to 404 error, backing out to home it came up 404 error and that was that...when i connect the modem all leds white and acting normal but no internet connection thought led says it is so it might be seeing the modem but not letting anything thru or me in....can a router "lock up" so to speak?
What FW is loaded on the router?
What browser are you using? Try MS Edge or Firefox or Opera
Be sure to clear out all browser caches before entering into the routers web page.
