benreg
Aug 08, 2022Aspirant
R8900 Nighthawk Plex version 1.24.4 needed for live TV to be enabled
I know Netgear support for the Plex is questionable. The LIVE tv guide has stopped working. The error message on the Plex app states "Error Loading Content. Live TV requires Plex Media server version...
Aug 09, 2022Guru - Experienced User
Its doubtful to happen. the last 3 releases for the R8900 were security fixes and thats it.
It hasn't had a plex update since 8/2021.
Its a bit sad that plex is now requiring a later version that prior with live tv.
If it was me? I'd move to a HTPC for running your plex server. I made the jump and haven't looked back because its much more capable now. Better transcoding, storage setup, smoother. It just works better.
benreg
Aug 09, 2022Aspirant
Thanks for the info. I guess Netgear has forced our hand. Built-in Plex was a selling point for me initially. Too bad we can't just install the update ourselves. I am looking forward to a more smoother experience with a dedicated HTPC server. 😀
- microchip8Aug 09, 2022Master
You should let routers do what they do best. ROUTING and SWITCHING. The fact that NG slaps a Plex server on a router should not make you consider that router. Routers are not meant to run such things and NG is deceiving you as a customer.
If you want the whole media experience, get a NAS and put Plex/Kodi on it. Routers are too weak and not meant (as I mentioned) for such things. To NG, this is jus an advertising "feature" in the hope it sells more to clueless customers.
- plemansAug 10, 2022Guru - Experienced User
The problem with it is they're using ARM processors that are top of the line at the time at the time they're released. They had just enough power when released to run plex and its complexities (not full transcoding)
Sadly, look how fast phones go out of date and are slow because they're using ARM processors. The R8900 was released in 2017 which had a great processor when it was released. 5 years ago. They go out of date faster than desktop processors because the desktop CPU had extra power for running transcoding and things like that.
So it worked great when released but 5 years later, not so much because plex has grown in size, complexity, and its processing demands.
