benreg
Aug 08, 2022Aspirant
R8900 Nighthawk Plex version 1.24.4 needed for live TV to be enabled
I know Netgear support for the Plex is questionable. The LIVE tv guide has stopped working. The error message on the Plex app states "Error Loading Content. Live TV requires Plex Media server version...
benreg
Aug 09, 2022Aspirant
Thanks for the info. I guess Netgear has forced our hand. Built-in Plex was a selling point for me initially. Too bad we can't just install the update ourselves. I am looking forward to a more smoother experience with a dedicated HTPC server. đ
microchip8
Aug 09, 2022Master
You should let routers do what they do best. ROUTING and SWITCHING. The fact that NG slaps a Plex server on a router should not make you consider that router. Routers are not meant to run such things and NG is deceiving you as a customer.
If you want the whole media experience, get a NAS and put Plex/Kodi on it. Routers are too weak and not meant (as I mentioned) for such things. To NG, this is jus an advertising "feature" in the hope it sells more to clueless customers.
