eiuwolf
Jul 07, 2022Follower
R900 Issue
I have R900 router. Modem is single port in DHCP ( Charter ). If I feed Netgear (dumb/unmanaged) switch first which then feeds the router and my pc, the router will never go online. If I leave in the...
Jul 07, 2022Guru - Experienced User
R9000 router? R900 isn't a valid model?
What is brand and model of this switch your using?
What is the brand and model # of the ISP modem?
Be sure that you are configuring the switch in the following connection configuration:
ISP modem>Router>Switch<PC and wired devices connected to the switch.
