fastcore
Mar 06, 2022Aspirant
R900 security updates took me from 400-600mbps up/down to ~3mbps down 0.1 up - firmware V1.0.5.40
About a week or two ago I saw there was an security update for my router. It had done a bigger update automatically maybe a month ago but this last one just ruined my network speeds. Firmware V1....
- Mar 06, 2022
What devices are you using to speed test with?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
fastcore
This is my current speed over wired
