fastcore
Mar 06, 2022Aspirant
R900 security updates took me from 400-600mbps up/down to ~3mbps down 0.1 up - firmware V1.0.5.40
About a week or two ago I saw there was an security update for my router. It had done a bigger update automatically maybe a month ago but this last one just ruined my network speeds. Firmware V1....
- Mar 06, 2022
What devices are you using to speed test with?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update?
Mar 06, 2022Guru - Experienced User
fastcore
The long power down helped, I was too impatient originally. Back to 500mbos up/down. Really glad I don't need to wipe and redo all the rules/reservations/etc. Thank you!!
- FURRYe38Mar 07, 2022Guru - Experienced User
If it happens again, would be good to know what ISP modem you have.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- fastcoreMar 07, 2022Aspirant
Its a AT&T branded 5268AC Gateway. I don't have it set up to bridge because it never seemed to work. Also never figured out plugging the fiber directly into the R9000.
Ya those don't bridge well or at all.
Try using the modems DMZ or IP pass thru for the R9000 router. This will help with the double NAT issue and probably speed issues. Then you'll be fine.
