applefanboy
Jun 05, 2022Aspirant
R9000 — Nighthawk X10 AD7200 transmitting 5ghz but not accepting connections
Hello, I have a R9000 — Nighthawk X10 AD7200 Smart WiFi Router. The router is transmitting a 5GHz signal but not accepting any connections to it. So far I have tried: Installed dd-wrt Issu...
Jun 07, 2022Guru - Experienced User
What happens if you disable WPA security on the 5Ghz radio, then does anything get connected? Set WPA2 and AES after testing this.
applefanboy
Jun 07, 2022Aspirant
The modem is a Netgear C7000. I attempted to disable security and connect; I am still unable to do so. I also changed the security option and changed the password, same result. I presume it must be a hardware issue at this point.
- FURRYe38Jun 07, 2022Guru - Experienced User
What mode is the C series modem in? Bridge?
What browser are you using? Try MS Edge or Firefox. Factory reset the router and setup from scratch. Use the configure router yourself option.
Disable Smart Connect.
Disable WPA security...can you set this here?
- applefanboyJun 07, 2022Aspirant
Since the C7000 is a modem/router combo, I have the router mode disabled on it. It is functioning solely as a modem at this point.
To answer your browser question, I typically use Google Chrome to manage and maintain any router settings and configuration. Does Edge or Firefox offer me something Chrome does not?
Smart connect has always been disabled as it is a feature I do not like. I have done what you have suggested to no avail. After setting up from scratch, I can see the 5ghz channel in my available networks but am unable to connect.
I'd give Voxel's 3rd party FW a try and see if this changes anything. If it doesn't then I would presume there is a HW failure.
