L101314
Jan 05, 2023Aspirant
R9000 - Nighthawk X10 SFP port
Good morning all, I am interested in this router and ask myself the following question: is the 10Gb SFP port usable with an AGM-731F type SFP module in order to be able to connect this router to my...
Jan 05, 2023Guru - Experienced User
Something you should try and see. Get something from a place that has a good return policy.
I got this one from Amazon:
Cable Matters 10GBASE-T 10 Gigabit SFP+
I had it in my XS505M but ran into something that I found out wasn't the SFP issue. So I swap it out of the switch and into the R9000 and works. I don't have Fiber support here so would be something to try and see. Send back if it doesn't happen to work.
