foxbrady
Feb 04, 2018Aspirant
R9000 - only getting 25% WiFi speed on 802.11ad 5GHz
I purchased the router brand new yesterday and upgraded our internet service to 800 mbps, but I am only getting 200 mbps over wifi (I do get 800 mbps with ethernet cable). I have a brand new Dell Pre...
- Feb 05, 2018
foxbrady, 300.0 Mbps PHY speed explains a lot. schumaku is right, that PHY rate implies 40Mhz channel width, but you should be able to do better?
On Dell PC:
- log in as admin
- computer management / device manager / network adapters
- double click on adapter / click on 'Advanced' tab
- Check these adapter properties:
- channel width for 5 GHz (want auto)
- HT mode (want VHT)
If those settings look OK, sign onto router and verify the 5GHz wireless settings: For "mode" (speed) of 5GHz -- want 'up to 1733', which is 80Mhz channe (other settings reduce channel to 40Mhz and 20 Mhz).
foxbrady
Here's a screen shot of my adapter. Notice the 300 mbps speed. Does this speed indicate the max proving your point?
duckware
Feb 04, 2018Prodigy
The "Dell Wireless 1820" is the problem. 2x2 MIMO is the limiting factor. I hope "Understanding wifi speeds" at duckware.com/wifi helps explain why...
