Ra-Dzik
May 26, 2021Apprentice
R9000 - problem with VPN IPSec
Hello, after the firmware upgrade (to version 1.0.5.28) I observe problem with connection through VPN IPSec (Cisco AnyConnect). After several hours of work, I cannot connect via VPN. A reset ...
May 26, 2021Guru - Experienced User
here's the order i'd try.
1. factory reset the router and reinstall. Sometimes old settings cause issues.
2. reinstall the firmware. maybe something didn't install correct and is corrupt.
3. downgrade the firmware. maybe it did introduce a bug.
- Ra-DzikMay 27, 2021Apprentice
Are you writing seriously?!
Factory reset and setting up all settings and computers from scratch is a half day job!
This is not a solution to my problem :-(
- plemansMay 27, 2021Guru - Experienced User
Ra-Dzik wrote:Are you writing seriously?!----didn't you post on here? So I'm writing to respond.
Factory reset and setting up all settings and computers from scratch is a half day job!----then maybe simplifying your setup or how you're doing it is in order if its taking you a half a day to install a router.
This is not a solution to my problem :-(-----Ok, do you see a giant "fix it" button on it? No? I dont' either. There are no simple "click this" and its fixed buttons.
