Ra-Dzik
May 26, 2021Apprentice
R9000 - problem with VPN IPSec
Hello, after the firmware upgrade (to version 1.0.5.28) I observe problem with connection through VPN IPSec (Cisco AnyConnect). After several hours of work, I cannot connect via VPN. A reset ...
Ra-Dzik
May 27, 2021Apprentice
Are you writing seriously?!
Factory reset and setting up all settings and computers from scratch is a half day job!
This is not a solution to my problem :-(
May 27, 2021Guru - Experienced User
Ra-Dzik wrote:Are you writing seriously?!----didn't you post on here? So I'm writing to respond.
Factory reset and setting up all settings and computers from scratch is a half day job!----then maybe simplifying your setup or how you're doing it is in order if its taking you a half a day to install a router.
This is not a solution to my problem :-(-----Ok, do you see a giant "fix it" button on it? No? I dont' either. There are no simple "click this" and its fixed buttons.
