LucaBilla
Nov 17, 2021Star
R9000 - WAN VLAN Setting
Hello Community! I posted this problem days ago in the Italian Community but no "reasonable" answer received. So I'm trying here :) In Italy if you need to use your Router with Fastweb (Italian IS...
Nov 17, 2021Guru - Experienced User
Id give Voxels FW a try. You can always revert back to stock of his FW doesn't work.
LucaBilla
Nov 18, 2021Star
I tried DD-WRT but the configuration is quite "complicated".
You should have BIG competences in Linux / Networking domain, not exactly the use case an "home" router is pointing to.
I didn't succeeded in configure it, and I have "some" competences in it.
We do "simply" need a checkbox in the "internet wan" configuration tab where to indicate the VLAN id for the WAN, nothing complicated.
(All the other routers, also the cheapest ones, have it).
- FURRYe38Nov 18, 2021Guru - Experienced User
I'd post about that over in the DD-WRT forums. Someone there may have more help and information regarding this and DD-WRT.
- LucaBillaNov 18, 2021Star
Already did.
Pretty impossible to understand the answers.
What I understood is that R9000 has a "strange" hw internal switching configuration.
There is not just 1 switch but 2.
And this complicates a lot the VLAN / forwarding configuration. I tried several options but nothing worked, but my fault for sure.
In those forums there are ENGINEERS with HUGE competences.
Too high for my understanding.
Well I did mention Voxels FW to try out. His FW is less complicated and uses same UI as NGs UI.
